Arlo netgear 2 cameras needing to disarm to turn off motion detection and notification?
I have an older version of netgear arlo station and 2 cameras. It doesn't have the same pencil edits. I want to turn off motion detection and notifications. Does this mean that I can click the disarm button ? OR do I have to just change the sensitivity level on the motion detection bar? Is low or high end more sensitive?
What mirror screening app will allow me to view on my Pc and Samsung android simultaneously without logging out of one or the other first?
Thank you,
Betta
Using the Disarmed mode is the easy way to prevent recordings and notifications.
You could use Google Home to cast your screen to a TV that supports casting.
Hi
Google Home is an app for your phone/tablet that will cast your mobile screen to an appropriate device (smart TV, etc.) even if the app itself doesn't support casting.
