Would like to reduce motion sensitivity
The motion detection test setting doesn't save. It's just to give you information which you can use in your modes and rules. All settings are in your rules. The FAQs have complete directions as do many threads here. Basically, use the Mode tab and select your base. Check out the default Armed mode and create your own custom modes so you have complete control.
There is a sensitivity adjustment on the motion detection test tab for the camera. it is a slider bar you can adjust. I am having the opposite problem. About 6 feet is the zone where the camera comes on. Maybe we need to trade cameras.
Thanks for the information. I had not found that setting before.
Burke
