Arlo is showing constantly offline and just shows everything in red
  • 1 Reply
  • 1140 Views
electronikjunk
The entire system is just plain overpriced junk.
Using Ring system in parallel without any problems for the same number of years.
Arlo cameras are constantly off line and if working just show everything in red. JUNK
JessicaP
Hi electronikjunk,
Are you still experiencing where your Arlo cameras are offline and showing red? If so, try to reboot the camera by opening and closing the battery compartment door. Allow the camera to sync back up to the base station and try again.
If you still experience the same behavior, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
