I've realized that they're not spending any time on fixing defects. They're not adding any functionality to the web portal that they also add to the app. Flash is going away soon, and Arlo has made no move to move their portal interface away from Flash. I'm guessing they're just going to let it die and not provide that interface any more.
What say you Arlo?
Do you mean myarlo?
Did you know that you can check the version of the "web portal"?
- settings
- about
Mine says Released 10/8/2019.
In Arlo time, which has nothing to do with real world time, that probably means 8 October 2019.
Is five days old too ancient for you?
What defects do you detect and what features are missing?
@Macahi wrote:
...Arlo has made no move to move their portal interface away from Flash.
That seriously needs fixing on Arlo's part.
Just another user
