  • 3844 Views
Terry3112
How do i set up different location of arlo example home then 2nd home?
steve_t
Master Master
Just take the base station with you along with the cameras. For the duration of the trip, take the batteries out of the cameras. When you get to your 2nd home, plug the base in and wait for the 3 green LEDs to light up. Then put the batteries in the cameras. They should connect automatically and you can then mount the cameras. If any of the cameras fail to reconnect, remove them from the base via the app and then go through the sync process again
steve_t
Master Master
Oh, I've just realised, do you mean moving the system to your 2nd home or buying a second second system for the 2nd home?
Buy a secondbase unit and cameras.... ( watch the total number of cameras as more than 5 is a paid level )
Sign in to the account and use ADD DEVICE for the base , then cameras
