Arlo hub Vmb 4540 compatibility with camera vmc3030
I'm planning to change my Arlo hub to the VMB4540 and would like to know if my old VMC3030 cameras will work with it.
Thank you
Message 1 of 2
290
Thank you
They will. The VMC3030 is called the Arlo Wire-Free Camera in these lists:
But quite a few folks have found that they cannot reinstall their legacy cameras after they remove them. So if your old hub is working, I'd leave the cameras connected to it.
Is there a particular reason why you want to upgrade the hub?
Message 2 of 2
282
