Arlo cmera, base station, verizon 5510L setup
  • 1 Reply
  • 1960 Views
eagleclaw
I am new and can see all the questions but cannot see answers. Replies just ask more questions. I also see I have replies to questions I asked, but reply page shows no replies. New topic: The Arlo base station I have would not come on after a week. I see it is a very common problem. I am an EE and disassembled the base station. I found the on/off switch was intermittent, but on mine if you wiggle the switch and hold on for a long time it will eventually come on. I have been unable to see what ARLO help says about all the failures. Sounds like
you may have voided the warranty by disassemble... normally you would return it for a new one.
Only thing i can think as you are an EE, is to bypass the bad switch and just unplug to reboot as needed....again this would be a last case scenario
