With the current IOS app, 2.4.2, I get every camera ever installed listed in the Library when I try to filter. Even the Arlo Pros that I tried and had issues with and an old Arlo that was defective and replaced with a new one are still listed. The Android app (current version) does NOT list all the cameras I ever owned, just the current ones installed. I removed the app and reinstalled, no change.
Have you reset the base ? try it...
Also if able use a PC at https://arlo.netgear.com/ and go into settings to see if the cameras are listed there...
if the old cameras are listed there ( ones you don't have ) use the remove device command.
Open a case with support. This is weird.
Thank you for contacting NETGEAR Arlo Support. I do apologize for the delayed response and for the inconvenience that this may have caused you..
My name is Kirby and I will be assisting you with this case.
I encourage you to visit the Arlo Idea Exchange
(https://community.netgear.com/t5/Arlo-Idea-Exchange/idb-p/arlo-idea-exchange) and post there so that this idea get's proper exposure!
This will help you this case will be taken properly from the right department specially for development of the products and features request.
Regards,
Kirby
Expert ID 46147
NETGEAR ARLO Support
I other words, it seems they just want me to ask the community here, and are done looking into the issue!
I guess it is too hard for them to contact the iOS app developer to inquire!
I've had inappropriate responses myself. I just reply back detailing what's happening and why the response wasn't useful. Not keeping them on their toes won't get you help - staying on them will.
Did you find a solution for this?
I have exactly same problem
Same problem on my iOS device. Called Arlo Support, but 1st-line support told me it's normal. I told her it's unacceptable. Created a case for this issue, but hasn't get anywhere yet. Let me know if you have already resolved this issue.
Same issue.. no fix.
