Arlo camera wont turn on
  • 1 Reply
  • 2695 Views
Ba2sai
Tried to sync my arlo on the base station then after syncing them on the app it says firmware update. The update was taking so long and failed several times. So i removed the battery, and remove the camera from the app, hoping that repeating the process from step one will make it work but when i press the sync button on the camera, no blinking LED, the camera is dead on wont turn back on. Please help.
Ba2sai,
It sounds like the batteries may be depleted, replace the batteries and then try again. Do you still experience the same behavior?
