My battery's went flat. It was off for quite some time. Got new batteries. Went flat real fast 2nd time. New batteries now and the camera would not work. I swapped batteries to another camera and it works fine. So I disconnected camera and tried to sync it again. It will not sync. What are some suggestions
open battery door, confirm batteries are in right, close
Attempt to sync ( make sure u do a quick push on base sync button, not hold )
IF NG,
Open battery door again, close...go to settings and use REMOVE DEVICE, then bring back as if it was new ( resync )
I have this same issue and started about a week ago. I have it on two cameras and neither of them will sync at all.
IF NG,
People this worked well. The only difference I did compared to previous was to do a quick push on the camera switch. I also noticed that once done the camera need updating. So weather this was part of the issue I don't know.
but once again. It worked. Thanks heaps guys.
