  • 3790 Views
ChrisEd
My battery's went flat.  It was off for quite some time. Got new batteries. Went flat real fast 2nd time. New batteries now and the camera would not work. I swapped batteries to another camera and it works fine. So I disconnected camera and tried to sync it again.  It will not sync. What are some suggestions
open battery door, confirm batteries are in right, close
Attempt to sync ( make sure u do a quick push on base sync button, not hold )
IF NG,
Open battery door again, close...go to settings and use REMOVE DEVICE, then bring back as if it was new ( resync )
nwooten
I have this same issue and started about a week ago.  I have it on two cameras and neither of them will sync at all.
IF NG,
ChrisEd
People this worked well.  The only difference I did compared to previous was to do a quick push on the camera switch.  I also noticed that once done the camera need updating.  So weather this was part of the issue I don't know.
but once again. It worked. Thanks heaps guys.
