Hello, I just bought a wire free arlo system from walmart with three cameras in the pack. I noticed that the motion sensor doesn't seem to work unless the camerais fairly close to the moving object. is that distance adjustable. Also I noticed that there is a mode tab on the program with scheduling. were can I find literature on how this works . Can I automatically make the camera record at certain times?
No, the camera will not record at set times....
The schedule is for "arming" the cameras at certain times to allow motion detection.. The cameras are a detect motion- then record system
best thing to do is go thru the FAQs
https://community.netgear.com/t5/Arlo-Knowledge-Base/tkb-p/arlo-knowledge-base
Zeustheo,
Motion detection works best within 10-15 feet from the camera location. This range isn't adjustable but increasing motion detection sensitivity may help: How do I change the motion sensitivity on my Arlo camera?
