Hello there,my arlo camera is still falling offline after following battery or pairing solutions from the arlo forum,any other troubleshooting advise, many thanks!
That may be due to the location. Swap cameras around temporarily to see if the problem is the camera or the location.
Will swap,many thanks,both cameras@ 3m away from receiver,battery@ 95%,no walls or obstructions!
Same as before,full reset started with no success, any other options??
Open a case with support using the Contact Support link at the bottom here.
