Arlo camera keeps going off line
camera keeps going off line and when its on line doesn't pick up motion until vechicle has almost passed by.Would a wi fi booster solve this problem? The router is about 65-75 feet away
NO...... The Arlo cam talks ONLY to the base.
But if you have a weak signal causing the problem, you could use a wifi extender (with Ethernet port) to locate the base closer to the cameras and solve the issue
As to slow response to motion, have you adjusted the sense level?
