Arlo camera is out of power in one/two days. Battery goes empty quick. Had product for 2-3 years.
Hi Guys,
Since a few weeks im struggling with one of my cameras, (netgear setup) its go's empty on battery very quick, and turns offline.
What is the status:
*I synced the hell out of it.
*Replaced it with 3 new battery sets
*The camera is dry on the inside (and also mounted under a roof)
Im suspecting a capacitor in the camera is gone bad,
The set is about 2 -3 years old, can't find the bill anymore..
Im located in The Netherlands, anyone have a tip or solution ?
Thank you in advance,
Best regards, Peter
0 REPLIES 0
