Arlo camera how to stop going off every 1-2 minutes? Delete bulks from library?
  • 1 Reply
  • 1034 Views
Laynee34
How do I stop one of my cameras from going off every 1-2 minutes? Also is there a way to bulk delete from the library?
Let's figure out the triggering first. Check you modes and rules - turn the sensitivity way down. Put the camera in a room with no motion to see if it still triggers. Remove the camera from Settings, My Devices and resync.
Bulk delete by using the Select link at the top of the library for the web or long press on one video for the app and start selecting others.
