Hi All,
Have had my Arlo camera for a couple of years no.
Recently it has started 'falling off' the WIFI - appearing as "This Arlo device is offline Please make sure it is connected to the Internet." in MyArlo.
The internet is working fine as other devices are still connected.
Highspeed WIFI 100mb/s
Have power cycled the base station, this usually fixes it but has not today, camera is still offline.
Happens every month or so.
Using non-rechargable batteries.
Base station is right next to my router, plugged in via ethernet
Camera is about 5meters away from the base station on the other side of a glass window.
Any ideas what is causing this?
Have you tried "removing the camera" then resyncing it back to your system ?
I haven't but I sure can try!
Mine is doing the exact same thing. It ran fine for about a year and now we are having to reset it constantly and or the cameras will just go offline randomly. Its getting very frustrating. I really want to like these cameras but I'm struggling.
I have 4 cameras, all connected fine for the first 12 months or so. Since a May update I have one camera that keeps dropping the connection and drains new batteries trying to connect. It is the closest camera to the base station.
Maybe it's a bad camera?
Swap cameras around to see if it's the camera or location.
I power cycled my hub again and it resolved the problem, again.
Odd that this happens after a year of usage >:
I'm thinking about buying more cameras but two things really pushing me to Canary vs Arlo; this issue and the fact I can't find any rechargeable batteries that work with these cameras.
Hope they're the Tenergy 3.7v gold colored rechargeables. Then you have ones that are certified to work (not the silver 3.0v Tenergys). Nitecores also work for me
