Arlo camera connectivity
  • 2 Replies
  • 4419 Views
fraserm1
Hi all,
I have two cameras - back door, and front door.
Back door shows as 2 bars connectivity, records videos nicely, and I can consistently stream live.
Front door shows as 3 bars connectivity, videos that get recorded are often truncated and glitchy in the picture.  I can rarely stream live.
Is the front door camera faulty, bearing in mind it shows a full strength signal, or are there other factors in play when it comes to the quality of a cameras signal?
thanks,
Fraser
brh
The base station and the cameras both radios in them and that is how they communicate with each other. Try temporarily
moving the camera that is acting up to a different location and try it there. It could be an interference issue from some unknown source.
Brian
The easiest thing to do is to swap cameras around. That will tell you if it's the camera or location.
