  • 1 Reply
  • 1341 Views
DJN
I have two cameras, one of which has demolished its batteries in under 3 days. I have checked both base station and camera firmware and all appear to be up-to-date with no updates available. Night vision is enabled on both cameras. Is this likely to be a camera fault, or could there be other issues? Any insights would be appreciated. Thanks.
Attempt to correct by resetting camera ( open /remove/replace batteries ) and reset the base by power button ( off-on ).
Also try swapping the "troubled" camera with the one working well to eliminate the possible location issue. ( see if issue follows camera )
If it continues, contact Netgear Support at   https://www.arlo.com/en-us/support/contact.aspx
