I have an issue with my arlo system not resetting if it goes offline without having to physically touch the cameras and bases. I bought the cameras for when I travel or not inside my house. This defeats the purpose. Is there any way you can fix this bug. I have experienced this while I am away and it has been an issue for me. I look forward to hearing from someone regarding this issue.
Firmware 1.10.0.9_23037
Hardware VMB3010r2
VMC 3030
By any chance are you experiencing power outages that cause this to happen? We've noted that the base may not connect if it becomes ready before the rest of the network so recommend use of a UPS to plug your modem, router and base into. That way your network (and Arlo) remain up and working through most outages. This would be especially important for folks who aren't near their systems for long periods of time.
