Arlo base station amber camera light
  • 2 Replies
  • 1895 Views
JoshBear
All,
i have 2 arlo pro and 3 arlo cameras conencted to an original base station.  All cameras are working well but there is an amber flashing camera light on the base station.  I have deleted the base station from the account and then readded.   I then resynced all the cameras and whilst close to the base station all the lights were green.
Just put put all the cameras back in position and the light on the base station is flashing amber again.   All the cameras are working.
Any my thoughts what is causing this?  Only started two days ago.
josh
It is possible one of the cams is near max range... Move one at a time close to base if you can't fiq which one by signal level
JoshBear
Thanks. Didn’t realise that the amber light could reflect max range.   That is possible as there are thick brick walls around the house and a huge metal AGA cooker which messes with my Wi-fi net work as well.
Strange that that it only started a couple of days ago when we have been in the house for 12 weeks.
Josh
