  • 4 Replies
  • 4920 Views
yoruchisan
Hello,
i’m trying to set up my arlo cameras with xiaomi android tv and android tv box.
When i install app from play market it says “The Arlo Secure app cannot be run because we cannot confirm that your device meets Ario security standards...” and shuts off. When i install older apk version i can log in, but then app asks to trust this device, i press trust and then app shows “an error occured” or “can’t trust this device” or simply just nothing happens. Tried multiple older apk versions even from 2020, can’t figure out why doesn’t work. Maybe some of you has similar situacion and could help me out? Thanks 🙂
yoruchisan
I figured it out myself, thanks me.
TMK, two ways...
1) via Apple home kit
2 via  tv and Alexa / Gen 2 Firestick.  ( this worked well ) for live feed
there is some delay on startup but the only issue I had was using names that were very similar.
It didn't like names like cam1/cam2/cam3 but ok with den/living room/deck...
( prob due to speech recognition )
see;
Apple TV via apple home
https://kb.arlo.com/000062508/Can-I-live-stream-my-Arlo-camera-on-Apple-TV
Amazons Alexa via the amazon Fire stick ( gen 2 or better )
https://kb.arlo.com/000044726/How-can-I-use-Amazon-devices-with-my-Arlo-cameras?cid=arlolearnmore_v1...
https://www.arlo.com/en_gb/support/faq/000055108/How-do-I-connect-my-Arlo-cameras-to-the-Google-Assi...
yoruchisan
Well, i don’t want to use voice to open arlo app somewhere. I just want open arlo app on the tv and that it🙃
yoruchisan
thomasjohnsen
And how about sharing your solution with the rest of us?
