Yes, wifi connection is fine, I've cleared cache, force stopped numerous times - this is VERY frustrating!
A recent cloud update along with an update for the Android Arlo mobile app has been released that should resolve this issue. Please visit the app store and be sure you are up to date on the latest version of the Arlo Mobile App: Release Notes - Android App 2.4.10 - 26th March 2018
If you continue to experience this issue, please let us know.
I am experiencing the same problem which started with the recent auto update of the app.
It says to logback in, but the only way to do that is restart the phone to log back in.
No alerts are received as the app is not working as previous versions did.
I am experiencing the same problem on my android phone which started with the recent auto update of the app.
It says to logback in almost every time I go into the app, even if it's daily. On the logon screen, there should be a place to check "stay logged on".
Engineering is aware of this issue and hopes to have a fix available very soon. We apologize for any inconvenience caused, I will provide an update as soon as I have more information on the fix.
