Arlo and Arlo Pro base stations
  • 2 Replies
  • 4134 Views
lldill56
I purchased an Arlo 3 camera system. Now have ordered an Arlo Pro 2 camera system. Would I be able to use both base stations at the same time since there is a large area to cover?
Yes and you can mix and match all the cameras so you get what you need.
Hula_Rock
Prodigy Prodigy
Prodigy
......... also make sure that the base stations are not in close proximity of each other.  If you do not have a ethernet connection at the 2nd base station location, I highly reccomend the Netgear Powerline solution.
