Arlo Wireless installation ?'s
  • 2 Replies
  • 3317 Views
Raynienburg
When in Motion mode, the recording cuts off in 10 seconds despite the fact that there is still motion within the frame.  Is there a control for this inteerval time?
10 secs is the default... It can go to 2 mins.
go to MODE , pick the one your using and edit
pick camera , edit
under record function there is a slide bar for time amount
*** back out and save ( sometimes save is on the previous page )
pick camera , edit
Raynienburg
Thanks TomMac.  As you probably deduced, I'm a newbie to Arlo and am learning how to use Communities.  I noticed several privious questions on the same subject after logging mine.  Thanks for your patience
