Arlo Wireless Cameras Video Blurred or Frozen
  • 1 Reply
  • 956 Views
Recurvegurl
I have 5 Arlo cameras set up around my home. 80% of the videos recorded either freeze up after a few seconds or half the screen will be blurred for the entire video. I have tried resetting them and the base station as well as resyncing them, but nothing ever fixes the problem for good. Please help! These cameras have not recorded correctly since I bought them.
steve_t
Master Master
Sounds like interference. Can you use a wifi analyzer app (on android device) to see which channels are the least busy? Then log into your wifi router and manually assign the 2.4GHz network to the clearest channel of 1 or 6. Then wait til that takes effect. Then power cycle your Arlo base station. Then see if you still get interference
