Arlo Wire Free VMB3000 camera is not showing up. Tried re-syncing and reinstalling Base.
  • 2 Replies
  • 1474 Views
spider3045
I recently got a new router and modem that has led to the base station not showing up. Help threads suggest reinstalling base station which I did and now none of the cameras are showing up. When I go to resync camera's, they are doing nothing. I have tried to replace the batteries and all that happens is the light initially shows blue for a few seconds and then turns to amber after I hit sync.
I have tried to reinstall the base a few times and also just powered down the base, but no matter what I do the camera's stay amber when trying to sync.
Is there a way to clear the cameras from prior settings or anything else to try and sync?  Only button I can find on the camera is the sync button and pressing for a second up to holding it for over 10 seconds doesn't do anything different.
spider3045
Thank you for the help. These were all the steps I had been taking and the light stayed amber. I was able to finally sink them only after I replaced the batteries with fresh new ones on each camera. I had taken the batteries out for a day and even rotated them between cameras. The thing that finally worked was just a fresh pair of batteries.
JessicaP
Hi spider3045,
What LED lights are showing on your Base Station? And feel free to read this article to learn how to troubleshoot if your Arlo camera is not syncing with your Base Station: My Arlo camera will not sync with my SmartHub or base station; how can I troubleshoot it?
spider3045
