Arlo Wire-Free Camera night vision not working
  • 6 Replies
  • 9130 Views
Onemove
My Arlo camera doesn’t go into night vision at all anymore unless I take the batteries out and put them back in. The camera is less than 9 months old but has not worked properly at night for the past 2 months. At first if I disabled the camera and turned it back on night vision would begin to work, now nothing except take the batteries out works. I have even tried restarting it but to no avail. Does anyone know if removing the device and resetting it will help. I can’t keep getting a ladder out every night to pull the batteries. I have attached a picture of the camera tonight without the night vision working.
JessicaP
Hey @Onemove,
Try the steps below to see if this will fix the problem with night vision not working properly on your Arlo Wire-Free camera.
  • Remove the camera device in Arlo.
  • Remove the batteries and let it discharge for a few minutes.
  • Afterwards, place the batteries back on.
  • Resync the Arlo Wire-Free camera to the base station.
6 REPLIES 6
steve_t
Master Master
This'll sound weird but can you mount the camera upside down and in the app/web select the "Rotate Image" option to be set to on? Then see how that goes.
Otherwise, I'd be looking to get the camera exchanged for a new one. Where did you buy the camera?
Onemove
I am willing to try anything thanks very much for your suggestion. I bought it at Lowe’s not sure if I could return or exchange it. Love the camera, disappointed in it’s reliability. Not even out in the weather it is under a covered porch!
Onemove
Flipping the camera didn’t work, no night vision until I pulled the batteries and put them back in. I am attaching pictures
After removing batteriesAfter removing batteriesBefore removing batteriesBefore removing batteries
JessicaP
Hey @Onemove,
Onemove
That is one thing I have not tried but will 😊 let’s hope it is the cure all! I will let you know at dark tonight.
Onemove
So far the solution has worked! Three nights in a row the night vision has come on automatically 😁
