The web portal is broken. I cannot login or reset my password.
It's not an issue with my password as I can use it to login to the app.
The portal is making AJAX requests to https://ocapi-app.netgear.com/api which are failing. It looks like the API authorisation is failing (i.e. not my user authentication).
Here is a sample for the reset password AJAX request:
curl 'https://ocapi-app.netgear.com/api/resetPassword' -X OPTIONS -H 'Sec-Fetch-Mode: no-cors' -H 'Access-Control-Request-Method: POST' -H 'Origin: https://arlo.netgear.com' -H 'Referer: https://arlo.netgear.com/' -H 'User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.132 Safari/537.36' -H 'DNT: 1' -H 'Access-Control-Request-Headers: auth-version,content-type,source' --compressed ;
curl 'https://ocapi-app.netgear.com/api/resetPassword' -H 'Sec-Fetch-Mode: cors' -H 'Origin: https://arlo.netgear.com' -H 'Auth-Version: 2' -H 'source: arloCamWeb' -H 'User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.132 Safari/537.36' -H 'Content-Type: application/json;charset=UTF-8' -H 'Accept: application/json, text/plain, */*' -H 'Referer: https://arlo.netgear.com/' -H 'DNT: 1' --data-binary '{"email":"*******@gmail.com","EnvSource":"prod"}' --compressed
And the response:
{"error":{"code":401,"context":null,"message":"Unauthorized. User is not authenticated.","status_code":401}}
I'm assuming this OCAPI is not the same as Salesforce Commerce Cloud OCAPI, if it is you need to fix your access token.
Hey everyone,
You should be able to log in through the web portal on your computer using this link: https://my.arlo.com. If you're still experiencing the issue with logging in, please let us know.
UPDATE/EDIT: If the link above is not working properly, try to clear your cache/cookies on your browser or try using incognito mode or a different browser to see if that helps.
I have this problem too. Unable to login on 3 different browsers and 2 different PCs. Shut down all anti-virus and firewalls, rebooted PCs, cleared all caches and managed to change my password but still unable to login on Windows 10.
Likewise, I'm also unable to logon via the web interface
It looks like the web portal has been updated to a new (broken) version as the UI is different.
I had a browser with the old version loaded which worked fine. Unfortuantely when I logged in on the app, it logged me out of that one and I got the broken new version 😞
This is an Arlo programming error.
Thanks FoxRaynard
I guessed, the interface is subtly different. I wonder how long it'll take to fix ...
The Android app version still works (for now)
Same here.
No problem logging in using the Arlo app on my iPad or my iPhone.
But can NOT log in using either my Windows desktop's or Windows laptop's browsers (that include all recent versions of Firefox and Chrome).
Yes same problem here....app OK but windows unable to login.
Web keeps telling me something went wrong?
Same here but, is it just me? Or, has Arlo gone though a serious change lately. My system has worked perfectly for YEARS! As of maybe a month ago every week once or twice I have an issue, I would consider it possible that my whole system (all purchased together several years ago) is getting old but, if it isn't the base getting dropped causing a complete removal of the system and re-installation (their only fix really), it's the portal not working now? I literally just used it yesterday.
I'm using a MAC computer and have the same issue, cannot check on computer, but app on Iphone is working.
Yes, another quality release from the Arlo software engineers amateurs. Have they not heard of testing?
Surely they have some form of change and release management in place that involves a backout plan?
Surely the moment you put something live and you find no one can log in, then if you can't fix it in the space of a couple of minutes you invoke the backout plan, don't you?
Or is that just me?
Having worked in IT for 21 years I'm pretty sure it's them and not me....
engineersamateurs. Have they not heard of testing?
Or is that just me?
Actually, being a professional, you would run it in a test environment to make sure all was well, Right?
Or is that just me?
Well, yes, that goes without saying, although when dealing with Arlo of late...
Joking aside, I was giving them the benefit of the doubt as you do sometimes get funnies when promoting software between environments, so things can work fine in Dev or Test but then fail when going to Production due to unforeseen environmental differences. In that case though, you just back things out as quickly as possible while you figure out what the difference is!!
Agreed. Looks like they are hacking rather than reverting to a known good release though:
curl 'https://ocapi-app.netgear.com/api/resetPassword' -H 'Sec-Fetch-Mode: cors' -H 'Origin: https://arlo.netgear.com' -H 'Auth-Version: 2' -H 'source: arloCamWeb' -H 'User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/76.0.3809.132 Safari/537.36' -H 'Content-Type: application/json;charset=UTF-8' -H 'Accept: application/json, text/plain, */*' -H 'Referer: https://arlo.netgear.com/' -H 'DNT: 1' --data-binary '{"email":"***@gmail.com","EnvSource":"prod"}' --compressed
Respone:
<html>
<head><title>403 Forbidden</title></head>
<body bgcolor="white">
<center><h1>403 Forbidden</h1></center>
</body>
</html>
So the response has changed from JSON to HTML And still doesn't work 😐
And there is now an error message, 'Something went wrong' as helpful as that is 😐
Umm... that's a pretty fundamental change there! I'm assuming it should be one or the other and they should really know which it needs to be - that does smack of a panicked pressing of buttons to try and make it work again.... Keep an eye out - they'll probably work their way through XML and good old fashioned CSV files before long! ![]()
Yep same here. Screen goes red and tells me my passowrd can't be blank (when it wasn't)
I have read multiple posts saying the same, but I can't find any solution.
For months, I have had no issues logging in via google chrome. Today, the arlo landing site looks new, and I keep getting the error "Something went wrong, try again"
I have cleared the cache, cookies and history, and was obviously able to log in here to support, tho I couldn't go from this page back to the log in. I have tried to log in on both Firefox and Safari with the same result.
What's going on Arlo??
The password being blank message is after the page reloads, which is also not a great user experience.
Try entering your password and deleting it; you'll get the error message. This shouldn't display on page load before you get a chance to enter anything but it does 😐
I'm actually a Software Architect and build international eCommerce sites.
Arlo, do you need my help ? 😛
When I attempt to logon to the arlo website, I enter my password, and it disappears; I get a message saying that the password field may not be blank. A red message appears at the top of the page that says Something Went Wrong.
If I click on the "Forgot Password" link, the same message appears at the top of the page.
The app on my phone works fine.
This morning we cannot log in to acct to view cameras. It is a different format and says 'Something went wrong. Try Again."
What do we do? our password and log in we used for 3 yrs isnt working.
@jguerdat wrote:
Everyone contact support!
At least that would keep everyone busy trying to get help from support while Arlo mob tries to fix the problem. I have had to contact support several times in the past few months and honestly was such a huge and agravating waste of my time. The only solution offered to correct every problem I have had (not on my end) was to remove the entire system and re-install as if new. Hahaha!!
I can't login on chrome. Unable to access cameras and not happy.
Model: VMB3000, Windows
