  • 2 Replies
  • 6102 Views
Downunda
I've found that the cameras when attached to the outdoor wall mount can come loose. The main problem is that the round plastic securing nut comes loose. If you try and tighten it too much the thread strips.  The securing nut needs to be made of metal.
In the interim I've had to use loctite on the thread of the adjustable post, not something I'd prefer to do.
Swap out the locking knob with a normal 1/4-20 nut...easy fix
Downunda
One can fit a regular nut but it interferes with the connector for the solar panel and you can't plug it in ( I forgot to mention that  I'm using solar panels with all of my outdoor cameras).
