Arlo Solar Panel with use of the internal batteries?
I'm trying to use a solar panel but keep the batteries in the camera too , any ideas? the solar panel comes with a fake battey you stick in the camera but i want it to charge the batteries in the camera so i don't have to change them all the time AC power is not accessible where the camera are
Obv , you are not using an Arlo product as the 3000 models do not support solar charging.
And the solar panel does not produce enough power to run the cameras on there own.
If you attempting to think outside the box, there are a batch of old tread on modifying the older cameras.
SORRY CAN'T FIND ANYTHING ON OLDER CAMERAS TO USE A
modifying the older 3000 cameras AND BATTERIES WITH SOLAR PANEL
what you want may need to run external battery... I ran an Arlo HD off a 6v gells cell that was supplied power by a solar panel ( with voltage regulator ) to allow the battery to charge properly.
The 6volt cell was for a deer feeder... https://www.amazon.com/Moultrie-Feeders-Trickle-Redesigned-Connectors/dp/B001VMX5J4/ref=sr_1_17?dchi...
with their solor panel to match....
Remember that any thing done outside the box is on you and not Arlo/Netgear as they don't approve of modding.
also read;
extra info;
without batteries... https://www.instructables.com/USB-Power-Arlo-Camera/
with batteries.. https://wasserstein-home.com/products/wasserstein-arlo-solar-panel-with-internal-battery-compatible-...
