Arlo Q camera
I have a two camera system. One works perfectly; the other spent the last 8 days upgrading firmware. I then tried opening the batteries but with no luck, I then tried removing the camera from the system and re-installing and re-syching the camera but again no luck. Any ideas would be greatly appreciated.
Just one last thing to try - use a fresh set of batteries. Low batteries will not allow updates to occur. Worth a try (swap batteries between cameras if you don't have spares).
Otherwise, create a trouble ticket. Maybe it's just a bad camera.
