Arlo Pro Batteries Are Draining Fast?
You say Pro batteries but these are the original cameras, not Pro which use unique rechargeable batteries.
When installing batteries in these cameras, just lightly place them in their slots - don't push them down. Let the battery door do the pushing. Since these cameras use the batteries in two sets of two (front and back) the camera will operate on one set just fine but will only show 50% even with fresh batteries. A symptom of you pushing the batteries down is fresh batteries but only half capacity shown.
As for fast draining, remember that the spec is for <5 minutes per day of recording and live view. How many total minutes per day of these have you been doing? Another possibility is that something has changed in the environment to block or interfere with the signal between the base and camera. Has something moved, including the base or cameras? Has a new device that uses the 2.4GHz band, WiFi or not, been introduced near the base or cameras?
Do any cameras have normal battery life? If so, swap the cameras around to see if the issue remains with the camera or the location.
