Hi,
My home is running an original 4 cameras wire-free alro system. And recently I consider to get an extra camera for outdoor and thinking of adding a single Arlo Pro 2 into the system.
With the original VMB3000 base station, by adding a Arlo Pro 2 camera, do I still get the following features from that new camera as advertised?
- 2-way audio
- 3 seeconds pre-buffer lookback (with the solar panel)
Thanks a lot in advance!
Cheers,
Rick
All the Arlo cameras that use a base will work with either the new or older base units...
You get the audio as it is in the camera
You do not get the 3 secs lookback feature or zones unless the Pro2 is plugged into ac ( ng with the solar panel )
