The app has logged me out and I am unable to log back in.
ANdroid or IOS?
Either way, make sure you not on the PC as this will bump you off ( only one primary user logged in )
If not, reboot the base via the power button or do the same on you phone ( reboot with power off/on )
confirm your using the right log in info.
Wait for a couple of minutes and try to log back in...
