Arlo Home Security System - Can’t Connect
  • 1 Reply
  • 890 Views
DavidPerth
I have an Arlo Home Security system in Australia - any hints on how to connect it to the Arlo app as it does not seem to be an option here in Australia
The only work-around I know if is to create a new account while using a VPN that terminates in the US.  Then disconnect the VPN, and you should be able to add the security system.
Note if you want a subscription for the system, you would also need to use a US payment method.
