Dear All,
I live outside the US and I am using a Arlo Security System (3 HDs and 2 Q's).
I just read about the Arlo Plans in which you can add more camera's. Does thes plans "work" outside the US ?
kind regards,
Leon / The Caribbean-Curacao
If the location is not listed on that page, then Netgear prob does not support higher level service plans over Basic ( free ) with 5 cameras.
You would have to run another account with a different user id/ password.
You can grant access access to view cameras from one account to another so all could appear in that one login, tho you would not have 100% control.
check here; https://community.netgear.com/t5/Arlo-Knowledge-Base/What-are-the-available-Arlo-subscription-plans-...
TomMac,
thank you for our prompt reply,
I cannot find the answer in the links sent.
More specific: I live in the Caribbean, Curacao. Can I buy add more than 5 camera's and subscribe to an Arlo Plan ? Will that work ?
kind regards,
Leon
