Arlo HD doesn't turn off
  • 185 Views
Andrew6
I have an original Arlo HD. I used to be able to turn it off if I was working around to save the battery. Now the Arlo app on my phone shows the perpetual spinning circle in the center of my screen only.
I turned off my phone and removed the batteries from the camera a few times. I also removed the device (Arlo) and put it back. Unfortunately, that didn’t work either.
Please advise,
Andrew6
Andrew6
Hi Shayne,
No more. The message "This device is currently disabled and will not respond to mode change" pops up on the screen when I switch it off.
Works great, thank you.
Andrew6
ShayneS
Hi @Andrew6
Are you still experiencing this symptom? Do you see the same symptom on the web portal?
Andrew6
Hi Shayne,
Andrew6
ShayneS
@Andrew6 Thanks for the update.
