  • 9 Replies
  • 4156 Views
  • 2 Likes
Qgaard
I have the Arlo cameras. They do not respond to motion, even when set on 100 %
What am I doing wrong ?
Qgaard
Sudently it works 🙂
Thanks for all your comments !
Kind regards René
9 REPLIES 9
Hopefully not trying to see motion thru glass...that is NG, doesn't work.
Also have you ARMED them in the MODE section?  ( is the running man black above the cameras ? Arm the camera and then go to devices and check ( live view screen)..if gray the cameras are not correctly armed )
Whistlerrainbow
I am having the same issue - installed yesterday I was getting alerts then nothing.
Whistlerrainbow
Also, when I click live it gives a time frame of 2 hours ago...  Please help me out here.
Power cycling the base is always a good first step.
Qgaard
The manual says something about a blue lamp blinking, when there is activity infront of the camera. I get a message, that says, there has been activity.... but there is no lamp blinking, and the activity does not get recorded ???
I have restarted the base, with no result 😞
Kind regards
René
Qgaard
Does your blue lamp blink, when you move in front of the camera ?
Mine doesn't.
My live viev is live, an I can manuay record, and then see it in the library.
After activity i front of the camera, I sometimes get a red dot with a 1 in, saying that there is a recorded clip, but there is nothing when I click on it ????
Perhaps there is some setup problem with "the cloud" ?
Qgaard
Hi
Its not thru glass.... The men are black, and the live viev works perfect.
I can record manualy, and see it afterwords.
I get an alert, when activity in front of the camere, but it doesn't record the activity ???
I can't morse... sorry 🙂
Whistlerrainbow
Qgaard
Sudently it works 🙂
Kind regards René
