Hi
The error happened with an Android device. I installed the chime using an Iphone and it was Ok, After that I installed another chime with an Android but this time I was not connected with my wifi and the error did not happened, so the problem was change from my wifi to the one provided by the chime for the installation. Problem resolved. Thank you very much.
Could you provide a screenshot of this error?
Hi
