I had to disable my cameras, tried to renable them and they would not connect.
Restarted the base station, same issue.
Removed all devices to re-sync them, failed.
Factory reset the base startion and removed from the app, base staion added ok. Still cannot connect devices and made sure I was on 2.4 wifi.
Removed the batteries from the cameras for a bit, and tried again to sync them to the base staton. You can see the indicator light on the base station turn from amber to green, but still get a time out trying to connect.
Removed the iOS app as well and tied all of the above again, no go.
"Nothing" has changed on the home network.
Message 1 of 2
583
Which cameras and base?
Message 2 of 2
574
