Arlo Camera wire free
  • 8 Replies
  • 5898 Views
ywk
I replaced arlo camera exchanged.
And tested night time, but unfortunately result was same.
Night vision was too dark to see nothing.
Could anyone help solve my sad frustration and bad disappointing for Netgear Arlo.?
I like to attached my image scene.
steve_t
Master Master
Yeah, there's pretty much nothing there that's largely reflective. Additionally, the one spot of bright light coming through the trees might be throwing off the autoexposure setting. Tonight, go into liveview mode and move the brightness slider to full bright and see if that makes a difference. Otherwise, as above, you may need to add some motion sensing lights to the area or again, check out the Arlo Pro camera
Edit: Didn't see the comment above. Good stuff
8 REPLIES 8
steve_t
Master Master
The regular Arlo is limited by the amount of ambient light as well as the IR illumintors. Obviously, the IR illuminators require a relatively close object for the IR to reflect off. I can't see your attached pic yet but if the space is open and everything is far away, you won't see much.
The Arlo Pro has significantly better night vision and one may be better suited to your area. An add on Arlo Pro works with the original base station too
Take a day time picture of the same scene so we can compare the distantances your shooting...
The IR illuminators do fall off very quickly at 25-30 ft+ ( inverse sq law )... best is when within the detection range.
ywk
Thank you for concern and helos.
Here are daytime and night time picture.
ywk
The distance is too great for the camera illuminators. Research 850 nM IR spotlights on Amazon so you can use them for greater throw.
here's a shot of the Arlo at night... the small centered stump is 28-30 ft  and camera is 6 ft off ground
This is the best it will do, ... but in your case it may be the IR is totally off.
You can see them at night, they glow a faint red around the lens..... check this out at night to see them
ywk
Thank You very much. Your helps a lot better.
As your suggesion, I ordered Arlo Pro today.
I really appriciate your faithful advises.
I will see what happen after installed Arlo Pro Sys.
 See you.
steve_t
Master Master
