Arlo Camera doent sync with Base
I just bought a new Arlo camera (I had two already installed). i followed the sycn process many times but the blue led of my new camera never appear.
Do you get a blue LED flash when the battery is installed? This should happen on either the original and Pro models (you don't specify which one you have).
yes when i installed the batteries the led appeared.
It is the normal camera, not Pro by the way
thanks
still doesn't work. still impossible to sync
What indication from the LED shows - anything at all when trying to sync? Be sure to only press the base sync button briefly - don't hold it.
no led blinking at all on the camera.
i saw few comments on that i really just pressed the buttons without holding it both on base and camera
on the base just enough to have the proper sync led starting blinking
hope it is not the camera that is faulty 😞
