Arlo Camera Is Appearing Offline
  • 4 Replies
  • 4127 Views
Sarah44
The Arlo camera is saying offline please make sure your connected to the internet visit for help, it’s not letting me do anything. Changed the batteries, tried syncing again just getting nothing can anyone help because my other cameras are working fine
ShayneS
Sarah44, gutsurg
Have you rebooted your base station & try and remove and re-sync your camera again?
gutsurg
I have the same problem  Some time in the last 2 weeks i noticed it and only had the time now to try to trouble shoot.  I'm geting the  error " this arlo device is offline".
There was a thread back in May 2018 that documented many users with this problem And did not see that there was a resolution.
I have:
re-powered my main router
switched ethernet cables and ports
did a power reset and button reset ofthe netgear router
tried re-pairing a camera
I have a green light for power and a blinking green light on the internet connection LED.
appreciate assitance.
ShayneS
Sarah44, gutsurg
gutsurg
Yes. As per my message I did all those things. Also changed the batteries in a camera. I get a green power led and blinking green internet led. When I try to sync the camera. The dates led blinks green but never connects to the camera
ShayneS
gutsurg,
Have you contacted customer support regarding this issue? I have attached the link here - Arlo Tech Support
