Arlo Bridge work with Arlo HD Wire-Free Camera?
Does the Arlo Bridge work with the Arlo HD or Base Station? I have trouble getting a signal to one of the two Arlo HD cameras I have, which cover inside of my garage and the other the front door. Is there any other options that work? Do I need a second base station?
The Arlo Bridge is for the Arlo lights only....
you either have to centrally locate the base you have for signal to cameras or add a second base
you can relocate the base by Ethernet cable or a wifi extender with an Ethernet port to plug in the base
