I purchased the Arlo wire-free camera yesterday. 2 cameras came with it one camera after 1 day says battery life 25% second camera says 83%. This is not the re-chargable battery. Why would the battery life be at 25% after 1 day?
It shouldn't, but if you check the threads, 2 others stated they got weak batteries in the box just purchased..
Can u check the voltages with a voltmeter?
9598,
Was there a lot of activity on the camera in that time frame? Single strength could also be an issue, what is the WiFi signal strength indicator showing for the camera?
