Arlo Battery weird reading
  • 8 Replies
  • 3389 Views
Sa9aX11
Hi
Arlo Battery showed 3 bars (80%) and when I removed the batteries to place to a different area, there is the usual thing you have to do set right level, enough light, aim and test wireless and picture, doing this I found the batteries dropped 2 bars (10%) completely drain the batteries,
I couldn't use the Cam anymore. I got my multimeter and checked the batteries, found they are ok still holding V3.0 - 3.2 each batteries so I place them back and tried again but nothing it only lasted a bit then gone dead again, the Cam is located next to my router so it wasn't far, the Cam should work, batteries are still good. Next day found the Cam working again at the original state as was before 80%, all I did is I removed the batteries for a day place them back to the Cam.
Not sure what is going on here, defective Cam? this one is the second I got replaced.
Is the magnets causing this problem?
Sal.
8 REPLIES 8
Butikofer08
Bought my setup two days ago and already 3 out of 4 cameras are giving low battery warning and I've swapped out one camera so far due to the pink hue problem
How many minutes of recording and live view do you have?  Spec is for ~4 minutes per day for 4-6 month battery life.
Another possibility is poor WiFi between the cameras and base.  DIstance, obstacles, 2.4GHz interference, etc.
Sa9aX11
The distance and signal is the same I moved it around and battery reading was the same, the recording time I am using is 40s (max 120s) using best battery life, its during the testing and moving the Cam it drained complete, just strange to find the batteries went back to normal the next day. All I did is removed the batteries and left them out for 1 day after next day found the Cam working again (80%). Air or the cold charged the batteries? I thought putting in fridge probably fix it.
Sal
My experience with various batteries has shown little effect from temperature.  I'm sure COLD temps reduce life but I haven't noticed very short life.
One thing to note is that the battery indicator on the Cameras tab will show "depeleted" until status is updated.  Is it possible you just looked too fast when starting up the app?  Batteries won't completely replenish themselves after no use from depleted to full regardless of the amount of time - some renewal would be noted but not much.  I'm guessing it was just a display issue rather than actual but can't prove it.  A voltmeter would help but you'd need to read the batteries immediately after removing them from the camera since a no-load reading means little.
Sa9aX11
I didn't looked too fast I checked a few times it was showing just a little left, also I removed the batteries 1 or 2 hours and it was showing completely flat in 2 different areas, one in R7000 and the other Arlo Web Portal.
I left the batteries out of the Cam and the next day I placed them back and find it was 80% left, fully working. It just weird.
Sal
Sa9aX11,
Are you still having issues with your battery levels? Please let me know if you continue experiencing this issue.
Sa9aX11
JamesC wrote:
Sa9aX11,
Not so far its going fine, Arlo site showing I have 81% left on the battery.
It's a shame I have to revert R7000 firmware back to V1.0.6.40_1.1.90 to make Arlo Cam work. I just waiting for next firmware update.
Sal.
Sal.
You're not alone. This has been going on WAY too long.  There's been some indication that a new production firmware with Arlo support may be available in the next week or so but I wouldn't bet on it.
