  • 2397 Views
Larose609
I have 10 cameras mixed of arlo and arlo pros but one original arlo seems to drain batteries way faster than the others especially in a area where there is not a lot of motion. I have different versions of rechargeable batteries as well that I have tried also. It is outside in sun in Florida all the time. I have others outside with not the same issue. Thanks in advance for any comments.
ShayneS
Hi Larose609,
Have you tried remove an re sync this camera to the base station? What trouble shooting steps have you attempted so far?
K11
The amount of battery drain is related to the number of times the camera is activated, you could try the keenstone rechargeable arlo battery sale on amazon
There's an Arlo-approved set of rechargeable batteries by Tenergy. WHile other brands may well work, the price I see on Amazon is about the same as the Tenergy packs. Warranty issues could occur with non-certified batteries. It's up to you...
