Instead of an ethernet connection to my main network router, can I connect the Arlo Base Station to it via wifi? (Ethernet ports are all used and I don't want to try to add another device to get more.)
No...the base unit requires an ehternet port to connect to the internet.
Your options appear to be an inexpensive switch to give more ports OR a wifi extender with an ethernet port ( that the base will plug into )
Alas... but thanks for the quick reply!
