Arlo Base Station Default Password
  • 1 Reply
  • 17643 Views
LiamJ
Is there a default password for the Arlo Base Station?
For example, If someone accesses my network information and identifies the multiple devices that are connected - and decides to attempt to gain access via my arlo base station, can they access my network using a password that was pre-loaded in base station via (by way of) its factory settings? For example , example "abcd1234" or "admin".
Back to my original question, is there an Arlo Base Station factory default password stored in the device?
-----Thank you for any assistance you can provide-----
storm1985
Prodigy
Prodigy
You cannot connect to the Arlo SSID as that signal is not really for regular wireless clients like laptops or phones, it is dedicated only for your Arlo wireless camera. Even if there is a password (i dont think someone will give IF there is) you still cant get it to connect coz the base station is not a DCHP server so you wont receive any IP address.
